Let me know what you think.
  • Bills37
    • Jan 2010
    • 247
    I have a 34 HD VD that I am getting ready to sell. I'm kind of an Indian guy so this thing is the odd man out in my garage. Also and red blooded Indian rider will tell you that clutch is ass-backwards and I don't even want get into what possessed them to put the front brake lever on the left. Now to get down to my dilemma, while fixing a transmission leak I discovered that the key way in drive pinion has broken out. Now I have no issues with the engine it runs fine and I am loathed to tear down an otherwise perfectly good motor. My plan is to remove the motor from the frame and set it up in my mill and recut a new keyway 180 degrees from the original. I don't have any problem doing this for myself. The new keyway and key will be as good as new. My hesitation comes from putting it on the market, I don't want anyone to think I'm pulling a fast one. What do you think?
    • 8247
    Bill!
    Matched tapers hold themselves, like a nail in oak, even if there's splinters.
    Keys are either for indexing, or to pacify.
    (Lapping tapers is always a good idea, of course!)
    PS: If you take it apart, its broken.
    • Bills37
      • Jan 2010
      • 247
      Good point Mr. Cotton, I shall break out the dye and the lapping compound.
        • 8247
        Meanwhile, just for conversation, Folks...
        Anybody else taught that nuts were just assembly aids, and could be removed with full integrity of the 'set' tapers?
        Thanks in advance,
          • 2025
          Cotton If you want to try that theory please don't use my motor.
          Thanks in advance,
            • 8247
            Nobody's got the guts to try it, Jerry!
            But notice how tapered assemblies are often so secure they are testy to split, yet the nut is on the bench?
            It ain't the nut.
              • 2025
              The nut is good insurance.
              It ain't the nut.
                • 8247
                I've found nuts that were welded, Jerry!
                More 'insurance', or paranoia?
                • rudy
                  • Nov 2001
                  • 72
                  I used to finish grind internal taper bores, when there right the gage is stuck with a 1/4 turn.
                  • Paps
                    • Jun 2003
                    • 1814
                    In my opinion, the nut is mainly used to draw the tapers together better.
                      • 6044
                      Jacobs tapers, and Morse tapers come loose with some regularity on lathes, and drill presses. That's not a problem. A popped taper on a pinion gear in a motor. . . That's a p.i.t.a., and a problem.
                        • 8247
                        It takes shock to release a taper, Eric!
                        (Or maybe your machinery is shot.)
                        If you've got that kind of shock on a pinion, something else broke first.
                        The tapers that experience the most shock are transmission mainshafts with opposing chain stresses;
                        The nut saves it long enough to do real damage.
                        PS: Yes, Pa!
                        The nuts' primary function is for assembly, as it becomes a screwpress.
                        PPS: Absolutely, Rudy!
                        I did it religiously: http://virtualindian.org/10techfly.htm
                          • 6044
                          I've seen a Harley, and an Indian with sheered pinion gear keys. The life of a motor is nothing but shock, and torture; and if a motor will sheer a key, a taper doesn't stand a chance. But, as Jerry said, you can do whatever you want with your motor. I'll go with the belt, and suspender route, as per factory engineering.
                            • 8247
                            Eric!
                            Indian pinion gears aren't tapers.
                            No collateral damage on the HD?
                            I've seen plenty of destroyed tapers, but blaming the taper is like blaming a piston for a hole in it.
                            PS: Suspenders and a belt would be to weld it.
                              • 6044
                              I knew better than to respond to this nonsense.
