Originally posted by duffeycycles
View Post
Problem with S & S Super E "Shorty" Carburetor on '67 FLH
This will be hard to explain so I'll keep it simple as possible. I have a '67 FLH with stock timer, no problem. I have a "40 EL with an electric start setup with a '67 FLH timer as I don't need manual advance (w/early cap and bung). I had a problem with the body dragging on the underside with the boss on the shaft. The weights wouldn't return properly. With a shim it works fine now. It took a long time to get on to the problem. Thought it was weak springs, etc. I found that there is a difference in shaft, gear, and such from '65 to '69. So building one out of parts can add some small problems. Has anyone else ran into this. Inquiring minds need to know. I finally seen a small drag mark on the bottom of the base plate. There are some different part numbers for some of the self advance timer parts.DrSprocket
James, when troubleshooting, always do the simplist possible solutions 1st, then work your way up to the expensive extensive teardowns. Condensor, points, plugs, wires, coil...and see where that takes you. Ive had a bike do the same thing you are describing due to a shorted wire where it exits the timer hole.
Originally posted by jorrow View PostJames, when troubleshooting, always do the simplist possible solutions 1st, then work your way up to the expensive extensive teardowns. Condensor, points, plugs, wires, coil...and see where that takes you.... ..
Try a review of reply #8, James!
Cut to the chase:
http://virtualindian.org/11techleaktest.html
PS: Please.Last edited by T. Cotten; 07-10-2018, 03:59 PM.AMCA #776
Originally posted by jorrow View PostJames, when troubleshooting, always do the simplist possible solutions 1st, then work your way up to the expensive extensive teardowns. Condensor, points, plugs, wires, coil...and see where that takes you. Ive had a bike do the same thing you are describing due to a shorted wire where it exits the timer hole.
Originally posted by jamesgraulty View PostGood advice, and I've done just that. In this order: new condenser-no fix; new points-no fix; new plug wires-no fix; new coil-no fix. And I've examined all the wiring I can see at both the timer end and coil end and it appears in good order. I put new plugs in after the carburetor rebuild. The only time on them was the very short runs after each of the new ignition parts was installed, to determine if the problem still existed. I looked at them a few times. The front seemed to carbon up a bit, but cleaned up easily, and the rear was always clean. So today after the new coil went in I decided to pull plug wires while it was running to see what would happen. Mind you it was still popping and missing real bad. The excess gas would drip out over the backplate and you could see the flash behind the throttle plate each time it popped. When I pulled the front cylinder plug wire off the popping stopped and it actually ran smoothly on the rear cylinder. Put the front wire back on and the popping started. Then pulled the rear wire and it stopped running. So something is up with the firing of the front cylinder, for which I haven't a clue. And I switched the plugs to see if it was a bad plug. Did the same thing. Popping and spurting, but pull the front wire off and runs smooth, on just the rear cylinder. I don't know what else to do??
AFJ
Originally posted by AFJ View PostIs the intake valve on the front cylinder closing completely at each compression before firing?
AFJ
Are you fearful of a bubble-test?
....CottenAMCA #776
Originally posted by duffeycycles View PostCotton is right.Either bad intake leak or no fire on the front cylinder.Did you put a timing light on the front cylinder & watch to see if there is spark ? If it has spark it is most likely an intake leak.
But other things could be amiss,.. too.
(Never does only one thing go wrong at a time.)
....CottenLast edited by T. Cotten; 07-11-2018, 01:27 PM.AMCA #776
Originally posted by jamesgraulty View PostThanks again for the input folks. So I checked and the front cylinder has spark. I was pretty sure it always did but I visually jumped the plug wire to the end of the plug to see the spark. Then I tried spraying Wd 40 all around the intake ports and where the carb attaches to the manifold while it was running. No effect on anything. I don't have the stuff to do a bubble test. So I put in new manifold O-rings. This S & S set up uses just the O-rings and the metal band to attach the intake manifold. Carefully inspected manifold and ports while apart and could not detect any flaws. Made sure everything was real clean and lined up good going back together. Still does the same popping, and stops when I pull the front plug wire off, like before. Sprayed around everything after the new manifold O-rings went in. No effect. So assuming I've ruled out intake manifold leak, what's left? All I can think of now is it's valve related. Maybe a broken valve spring? Or something else in the valve train? Stumped again.
AFJ
Originally posted by jamesgraulty View Post... Sprayed around everything after the new manifold O-rings went in. No effect. So assuming I've ruled out intake manifold leak, what's left? ...
You have not ruled out a vacuum leak at all.
....CottenAMCA #776
Well I'm happy to report I've solved the problem. Remember when I said I thought the valve train clatter was getting progressively worse during the ride when this problem hit. Today when I took the front exhaust push rod cover off the push rod fell right out. And the lock nut was loose. I determined I have solid lifters, instead of the stock hydraulics. I adjusted all the push rods. It fired right up and is purring like a kitten. I've learned a lot from this experience. And the carburetor and ignition work and manifold o-rings isn't wasted. I've learned from it and know where these key items stand now. Thanks to all who replied to this thread. The input is very valuable, for now, and in the future. Thanks again!
