Missing Shop Dope
  • Lippy
    • Apr 2008
    • 114
    Missing Shop Dope
    I have a few bikes from the 30's and therefore am looking through all my orginal Shop Dope and those that have bee republished by Antique Motorcycle Supply and Harley-Davidson. There are quit a few missing from the 30's and would like to know, at least, the subject of those missing Shop Notes. If you have any of the following would you please post the date and subject title? Thanks. Here are what I'm missing: 48, 53, 66, 70, 72, 81, 86, 91, 94, 99, 100, 102, 103, 104, 105, 108, 109, & 110.
  • 23JDCA 808
    • Jan 2007
    • 688
    on eBay:
    http://www.ebay.com/sch/i.html?_from...+Vol+2&_sop=15
    Bill Gilbert in Oregon
    • Lippy
      • Apr 2008
      • 114
      Bill, that's for the reply, but those books that you link too is what I already have. They are incomplete and are missing the above listed Shop Dope's. Just looking for those missing ones. Lippy
      • wideglide38
        • Jul 2008
        • 656
        Found the following in H-D Pub. p/n 99410-93. You will have to pour through the manual as the S/D numbers are in consecutive order. A couple of S/D numbers were duplicated.
        48A - Inspection & Lubrication of Clutch Bearing; July 10, 1918
        53 - Harley-Davidson Two-Speed Hub; May 21, 1917
        53 - Inspecting & Overhauling the Clutch
        66 Revised - Attach Top & Windshield to 1918-19-20-21 Sidecars; Sept. 15, 1920
        70 - No data on-hand
        72 - Proper Push Rod & Exhaust Lifter Pin Adjustments (no date listed)
        72 - Cylinder Exhaust Seat Reaming Tool & Use; March 5, 1918
        81 Revised - Care of "E" Type Motor; May 10, 1921
        86 - Use Order Form #1315 for Replacements & Repairs; June 15, 1920
        91 - Lubrication & Carburetion of 74" Motor; March 1, 1921
        94 - New Manual Switch & Buzzer; June 15, 1922
        99 - Adjustment & Repair of DCA & E Motors; Nov. 1, 1923
        100 - Complete Timing Instructs for H-D Motors; April 1, 1924
        102 - Complete Timing Instructs for H-D Motors; June 10, 1926
        103 - No data on-hand
        104 - No data on-hand
        105 - No data on-hand
        108 - No data on-hand
        109 - No data on-hand
        110 - No data on-hand
        Regards,
        William
        William Edwards, AMCA #10035
          • 4789
          I have the following sheets,
          102 Dec 26 1932
          103 Jan 9 1933
          104 Dec 26 1932
          105 Aug 4 1933 (two pages)
          107 Jan 5 1934 which is different than the common 107 from Dec 11 1933
          I may have others but haven't looked too deeply into my piles.
          There are also odd numbered sheets mixed in the timeline and it is obvious that the numbering was not consistent. I also have a few with no numbers at all. Some of the missing numbers are dealer announcements telling of a new service began or an old service no longer offered, so they do not appear in the reprint collections as they offer no service information.
          • Lippy
            • Apr 2008
            • 114
            William, I want to thank you for your time and effort on finding and typing in your reply to my question. Unfortunately it's not exactly what I'm looking for. As I posted I'm looking for Shop Dope from the 30's and it looks like Harley started to renumber their technical information when they went from Service Dept. Bulletin's to Shop Dope. Apologize that my posting wasn't clear enough. Here's where Shop Dope that I have begin to talk about the bike's (specifically VL) in the 30's:
            43 Apr 06, 1929 Servicing Handlebars with Worn Slots (see No. 232)
            44 May 20, 1929 Heavier Spokes in Commercial Front Wheel
            45 Jun 18, 1929 Battery Filler Plugs / “45” (750 cc) Twin Improvements
            46 Aug 12, 1929 To Attach 1929 or Earlier Sidecar or Package Truck to 1930 Big Twin
            47
            SPCL Oct 31, 1929 Instructions for Fitting Late Units and Parts to Early 1930 74 Twin Models (below 3000)
            48
            49 Nov 4, 1929 Spark Plugs / The 1930 Twin Ignition Coil
            50 Nov 11, 1929 New Parts in 1930 Big Twin Models
            51 Nov 14, 1929 Fitting Specifications for all Dow Metal Piston Single Motors
            51A Nov 14, 1929 Fitting Specifications for 45 cu. in. Twin Motors
            51B Nov 14, 1929 Fitting Specifications for 1930 Big Twin Motors
            51C Nov 14, 1929 Valve and Ignition Timing Specification for all 1930 Motors
            51E Nov 14, 1929 Fitting Specifications for all Dow Metal Piston Single Motors
            52 Nov 18, 1929 The 1930 HARLEY-DAVIDSON ELECTRICAL SYSTEM
            53
            54
            54A
            54B
            54C
            54D
            54E Jan 13, 1930 Roller Bearing Rollers
            55
            56
            57 Apr 14, 1930 Important Notice on Cylinder Head Bolts
            58 Jun 30, 1930 Carburetor Back Fire Deflector
            59 Aug 4, 1930 Improved Seat Post Springs
            60 Aug 25, 1930 Gear Shifter Lock for the “45” and Single Transmission
            61 Sep 15, 1930 New Method of Timing Ignition on 1931 - 74 cu. in. Twin
            62 Oct 6, 1930 Use 1931 Type Cushion and Guide Rings when Servicing 1930 Motors
            63 Nov 1, 1930 New “45” Model Generator Drive
            64 Dec 15, 1930 Tuning Motors for Speed and Power (revised, see
            65 Dec 22, 1930 New Piston Pin Lock Ring
            66
            67 Jan 6, 1931 To Fit New Fork Side
            68 Jan 12, 1931 Fit Double Filament Headlight Bulbs Correctly / Increase Bulb Life by Reducing Generator Charging Rate / Rubber Speedometer Drive Gear
            69 Jan 19, 1931 New Constant Mesh Starter Gears
            70
            71 Mar 31, 1931 74 cu. in. Twin Motor Fitting Specifications
            71A Mar 30, 1931 45 cu. in. Twin Motor Fitting Specifications - (all Models)
            71B Mar 30, 1931 Single Motor Fittings Specifications - (all Models)
            71C Mar 30, 1931 Timing Specifications
            72
            73S Apr 13, 1931 Re-Enameling Prices
            Just trying to fill in the blanks. Thanks again, Lippy
            • wideglide38
              • Jul 2008
              • 656
              Lippy,
              You are welcome. Wished it could have been more helpful. I have limited info (H-D data reprinted by the MoCo and Shop Dope Vol. 1 - 4 by Antique Cycle Supply). Your data is not lining up with what I have. Was wondering if your S/D info is a collective document or are these individual service bulletins? Maybe other folks can fill in the gap for you.
              William
              • Lippy
                • Apr 2008
                • 114
                Robbie, you have a start to what I'm looking for. Can you post what the topic of each to those that you list?
                102 Dec 26 1932
                103 Jan 9 1933
                104 Dec 26 1932
                Lippy
                • wideglide38
                  • Jul 2008
                  • 656
                  I am looking for a copy of #69 (19 Jan 1931). I need to time my kick starter on my '35VLD. Does anyone have a pdf copy they can send?
                  William
                    Those are the ones published by Antique Cycle Supply. They are missing a lot of issues.
                    H-D reprinted Shop Dopes in book form a few, maybe quite and few, years ago. Contact the Service department at The MoCo and see if they are still available.
                      66, Service Department Bulletin. June 15, 1920. How to attach Top and Windshield to 1918-19-20-21 Sidecars.
                      70, 72,
                      81, Service Department Bulletin. Two issues with this number. June 20. 1919. Care of the 500 Type Motor. May 10 1921. Care of the "E" Type Motor.
                      86, Service Department Bulletin. June 15, 1920. Use our order form number 1315 for replacements and repairs. The reason for steel plate under one cylinder only, Sproket combination for double sidecar, Engine clamp plates on repaired frames, The three plate type of Exide battery, Fitting the Sport Model manifold. Sport model carburetor, Assembling sport model motor into frame, Tool for replacing recoil spring guide rods.
                      91, March 1, 1921. Lubrication and carburetion of the 74" motor, Operating new 74" motors just out of the crate, Adjusting Schbeler Carburetors, Carburetor and motor valve springs, Fitting the manifold to the 74" motor.
                      94, Service Department Bulletin. June 15, 1922. The new manual switch and buzzer,
                      99, MECHANICS BULLETIN. Nov 1, 1923. Adjustment and repair of DCA and E motors.
                      100, MECHANICS BULLETIN, April 1, 1924. Complete timing instructions for H-D motors.
                      102, MECHANICS BULLETIN. June 10, 1926. Complete timing instructions for H-D motors.
                      I have many that are only dated and not numbered.
                        Timing of the 1931-36 VL constant mesh kick starter is done by fitting the lowest tooth on the kicker quadrant gear between the two marked teeth on the starter clutch with the kicker in the vertical rest position.
                        • wideglide38
                          • Jul 2008
                          • 656
                          Chris - I have the same manual and several others.
                          Steve - I timed the starer last night. Once the side cover is off - very apparent. Thanks.
