Regular springer length vs XA.
    • 2025
    Does anybody know off the top of their head how much longer a XA/early WLA springer rear leg is when compared to a regular WL/EL/UL springer rear leg?
    Jerry
    Jerry
    Roughly 2 1/4". If you need exact I will go out to the shop and measure.
      • 2025
      Thanks Chris. No that is good enough.
      Jerry
        • 4791
        Jerry,
        Here they are side by side. they are generally considered 2-3/8" different.
        Robbie
        • Carl Olsen
          • Jan 2002
          • 261
          Robbie,
          Those are 45 springers, not big twin. One is a WLC and the other is a WL.
          Carl
          • Slojo
            Evil Twin Doctor
            • Oct 2007
            • 880
            Originally posted by Rubone View Post
            Jerry,
            Robbie
            Robbie
            Are you building a 54 pan? Small fin heads, hydraulic lifter filter.
            joe
              • 4791
              Carl,
              Did you note Jerry's question regarding XA/WLA forks?
              And no, one is not WLC. WLC did not use the long fork.
              One is WLA, the other is '40-early "41 WLA and South African WL. And whether Big Twin type or 45, the actual overall length of the forks is the same, the only differences being that the XA had a big stem but used 45 rockers and the ELC uses BT rockers..
              Robbie
                • 4791
                That is the plan Joe,
                But like all my projects progress is slow..
