Please help me ID these parts
  • MMasa
    • 1192
    I have these parts that I can't ID. Can anyone help me out?
    First up are these two styles of steel clutch? plates. The larger ones are a bit strange with the 2,3,4 spline arrangement.
    These look like normal Panhead pushrod cover tubes but they are completely, save the spring, made out of aluminum. Are these some older aftermarket thing or were they an OEM item for certain years?
    Lastly, I have a number of small unknown NOS parts. I have a number of each.
    Thanks in advance for any help you can offer.
    Anyone need any of it?
    Mark Masa
    Mark Masa
    www.linkcycles.com
    the pushrod tubes are gennie.
    • MMasa
      • 1192
      Cool. Thanks for the info. What is gennie? Is Gennie the name of an aftermarket parts maker? If so, about what vintage?
      Mark
      Mark Masa
      www.linkcycles.com
      • knuckleheadtim
        • Jan 2008
        • 141
        Clutch plates are from an automatic transmission, THM 350 if I remember.
        • upsrod
          • Feb 2010
          • 320
          Pushrod tubes are 60-62.
          • MMasa
            • 1192
            Which ones? The large, small, or both?
            Mark
            Mark Masa
            www.linkcycles.com
              • 4791
              Mark,
              Kyle (amklyde) was looking for some of those aluminum tubes recently.
              The bent bracket with the attached springplate is a buffer clip for the rear bumper on a 45 H-D. The kit came with both types, Big Twin and 45, so a few of those kicking around.
              The flat strap with the two holes is a brake line bracket for use on Duo-Glides with sirens.
              • cdndewey
                • Jan 2005
                • 438
                Originally posted by Rub View Post
                Mark,
                I disagree with you on the...... The flat strap with the two holes is a brake line bracket for use on Duo-Glides with sirens
                I could be wrong but the couple I have seen have a 90 degree bend on each end and aren't rounded on the very ends.
                  • 4791
                  You're right Dewey, the early ones have the bent ears, but the later ones ('67 up) do not. So it is a Shovel part, not Duo...
                  • cdndewey
                    • Jan 2005
                    • 438
                    Okay, the ones I saw were on a 60's DuoGlide and a 65 ElectraGlide.
                      • 2025
                      Mark
                      Looks like it could be a sidecar spring shim. 88170-24
                      • Sargehere
                        Member since 1972
                        • Jul 2006
                        • 971
                        Originally posted by Jerry Wieland View Post
                        Mark
                        I agree with Jerry. That flat plate with holes at either end is old number 6349-24, Sidecar spring shim, 1924 & later for LT, K, LE & M sidecars.
                        Gerry Lyons #607
                        http://www.37ul.com/
                        • knuckleheadtim
                          • Jan 2008
                          • 141
                          The smaller clutch plates are forward and direct, the larger intermediate for Gm THM 350.
                            Mark
                            Gennie = Genuine
