Clutch pushrod question??? 4 speed
  • harley1
    • May 2010
    • 74
    Hello All,
    Wondering if the clutch pushrod should go through the early style throwout bearing and into the clutch release finger? The new clutch pushrod (ordered for correct year) does not go all the way through the throwout bearing. See pictures. The new pushrod is farthest from the throwout bearing in the first picture. The old clutch pushrod is in place in the throwout bearing in second picture.
    Thanks!!
    I’m not in the shop right now but the clutch rod with the long nose looks like the early 36 style. All the ones on my 48 and up have the one you were sent. I got to look in the morning when I start working for Obama’s leaches. Bob L
      Well it's not the early one as it dosn't have the C clip groove on the end. The other one in the picture is oem out of my 48. I havn't got an ansewer on this one. Bob L
      • harley1
        • May 2010
        • 74
        Thanks for the info Bob! There is a slot in the clutch release finger that looks like the clutch pushrod should fit into. Also the old pushrod appears to have worn through the hole in the throwout bearing so it is hard to know how it should all go together.
        Good day!
        • larry
          • May 2009
          • 247
          The rod with the pin helps hold everything together during assembly.
          • len dowe
            • Oct 2002
            • 519
            pushrod
            the top pushrod goes for the pancake bearing. The cone bearing fits into the clutch finger and mounts with the cover with the bottom pictured rod. I could use the top rod if you don't need it. Len.
            AMCA #765
            • harley1
              • May 2010
              • 74
              Thanks Len, If I don't need it I will let you know.
              • vph-d
                • 1088
                Panheads have the blunt style of pushrod. The skinny nose type with circlip groove is from the mid 70s retro fit kits.
                VPH-D
