I am seeking info regarding selection of a motorcycle trailer. I want it to be enclosed with the options of one, two or even three full sized bikes. Although, being able to haul one or two would work for now. How about the suspension, rear door also a ramp, features that are worth having that you wish you would have known about when you bought yours? Are there any companies that I could check on the web or should avoid? Any comment good or bad regarding your experiences are welcome. Thanks !
Trailer Info Wanted
Check out www.aluminumtrailer.com you might find less expensive but you won't find better. Had them build one a year ago and extremely pleased. A great piece of craftsmanship!
johnny
Trailer
Here is another web site you should check out. I bought the 712 cycle hauler model with surge brakes on both axles. It works great. All aluminum, with setup for two dressers.
horton hauler
Here is the web site for horton haulers
I have one of these and it's great!
Rousseau
And from Ohio in the light weight cato. - 5K for this fiberglass and aluminum enclosed. Sure wish they would state what the overall weight is, must be light. I've seen a member or two haul one. They seem to like it behind a van.
http://www.trailex.com/viewprod.cfm?...t=98&cat_id=98
Found it. Gross 1200 lbs.
