Wr Engine ???
  • 51FL
    • Nov 2010
    • 207
    Wr Engine ???
    Hey Guys is the left CASE on a True Wr different from a Wl ??
  • diesel55
    • Jul 2011
    • 262
    Hello probably stamped wr. enjoy
    • 51FL
      • Nov 2010
      • 207
      WOW more good info provided by diesel55 , Thanks ...... Now maybe I should reword my question for the .... well you get the point .WHAT IS THE DIFFERENCE AS FAIR AS MECHINICAL DIFFERENCES , IE ROLLER TO TAPER TO BALL BEARING ?? ARE THERE ANY MAJOR DIFFERENCES ASIDE FROM THE NUMBERS??
      • gary.h
        • Apr 2009
        • 176
        hello 51 fl,i imagine you have heard of that site the beauty of speed? www.beautyofspeed.com maybe they might havesome info on any differences,,,take care.
        • 51FL
          • Nov 2010
          • 207
          Gary , Thank you . I had heard about them and forgot ,im gonna email him and see what he's got to tell me . Thank you again
          • gary.h
            • Apr 2009
            • 176
            no prob! hope you find answers,if you do post em here if you would please im, curious myself now,,take care eh!
            • 46WL
              • Feb 2007
              • 60
              Hi, a WR is machined for the large roller bearing. That is the only difference. Besides the stamped numbers.. If you need a picture, let me know.
              • 51FL
                • Nov 2010
                • 207
                Please for pictures , that would be very helpful ...
                • 46WL
                  • Feb 2007
                  • 60
                  here you go!
                  • fillibuster
                    red dog
                    • Aug 2009
                    • 934
                    Originally posted by 46WL View Post
                    here you go!
                    them's balls
                    • rwm
                      • Dec 2006
                      • 1302
                      is the bolt pattern the same on the cases? they look different on the 2 lower ones opposite of the drain plug .
                      rob ronky #10507
                      www.diamondhorsevalley.com
                        • 4791
                        Rob,
                        They are the same. A WL left will bolt to a WR right. The right case is the one with the differences. Ball bearings for the cams and crank, along with a different platform for the mag as opposed to a generator. Different for the idler stud as well.
                        Robbie
                        • Eric MATHIEU
                          • Sep 2008
                          • 70
                          Rub is correct, any WL left case will match a WR right case and vise versa.
                          Basically here is what is specific about WR cases that I know:
                          1941 - 1949 WR
                          - Setup for ball bearings on crankshaft & cam shafts
                          - Special casting for alternate position of idler stud gear used to drive front mount magneto
                          - Generator cradle machined differently to accept front mount magneto (Edison Splitdorf front mount magneto)
                          There was also a run of cases that with 1948 casting dates that had a slightly different size ball bearing on the left side but I don't know why.
                          Mid 1949 to 1950 WR
                          - New thicker castings throughout for much stronger cases
                          - New specific casting for Wico front mount magneto (large flat platform)
                          1951 - 1952 WR
                          - Modification in left side casting between the two cylinders. It looks like they added some material to have an oil circuit to the cylinder bases / pistons squirts but they never did it.
                          - Thick type castings throughout for much stronger cases
                          - Specific castings for Wico front mount magneto (large flat platform)
                          This is all off the top of my head so I may have forgot some details or got mixed up in the dates but that's basically it.
                          !!! 46WL !!! Is that a 1949 left side WR case? If so I'm looking for one. I have other year WR cases (1946) for trade of other WR stuff. Let me know.
                          Eric
                          Eric MATHIEU @ Beauty of Speed
                            • Feb 2003
                            • 5353
                            Well look at that Gary! You pointed things in the right direction and look at the info!!! Thanks for the WR lesson Eric!
                            Cory Othen
                            Membership#10953
                            • 46WL
                              • Feb 2007
                              • 60
                              Eric[/QUOTE]
                              Hey Eric- It's a '48, but I need it for a project. I could use a chromoly frame, though.
