Lynite Primary Cover-Help Identify
  • junkyarddog
    • Feb 2010
    • 193
    Can anyone identify or shoot me some leads to who might know what it fits?
    Casting #
    2
    20-D-1
    F
    Stamped LYNITE
    Thanks for any help
    Jim Rowin
    Omaha, Ne.
  • Bill Huth
    • Jun 2009
    • 64
    Hi Jim,
    I think it is an Indian twin helical gear driven primary case. I believe that style was used from 1920 to ?1932? However, I don't know the specific model yours fits, Scout, Chief, etc. Hopefully someone more familiar with these models can chime in.
    Regards,
    Bill
      • 6044
      It looks like Scout through 101 because of the boss for the generator drive.
      • junkyarddog
        • Feb 2010
        • 193
        Thanks Eric
        I was thinks this was going to be a hard nut to crack with no replys
        I would still like to narrow it down more if anyone can help
        Jim Rowin
        Omaha, Ne.
        • indianut
          • Feb 2005
          • 308
          It is a 37" Pre-101 Scout cover. The clue's are the Gen Drive was Scout only and the Small Trans was 37". If it were the large trans (45") there would be a indent at about 5 O'clock around the large hole when looked at it from the front. It appears that there are 4 studs for the Gen Driver and that would make it later in that run of style cover. I am not sure if the 37" 101 still used the Small Trans or used the same as the 45", but knowing Indian they probably used the same one, that is why I GUESS Pre-101.
          http://laughingindian.com/
          A.M.C.A. Member Since 1986
            • 6044
            Well, you got the right guy to answer your question Jim. Indianut knows Scouts.
