wheel hub rebuild question regarding felt seals
  • wheel hub rebuild question regarding felt seals
    Thougth I would post this here because there is not a section on wheels and the Indian section activity is typically low.
    I am rebuilding the front wheel hub on a 36 chief and my question is about what to do with the felt seals. I know where they go, but I do have the following question.
    Do I need to do anything to them prior to installation?
    Should I soak them in oil?
    Should I try to smear grease into them?
    What is the accepted standard for this?
    Thanks in advance,
    D.J. Knott
    AMCA #10930
    found this on a 4 wheel site, I'm just going to use oil.
    http://forums.aaca.org/f120/installi...ls-166132.html
    D.J. Knott
    AMCA #10930
