Fork Lock removal
  • OldHog66
    • Jan 2009
    • 113
    Fork Lock removal
    Hi guys,
    I have my '66 Frame ready for powdercoat.. except the fork lock. I do not have a key for it.
    Two questions
    1) does it need to be removed before powdercoating
    2) whether it does or does not need removed...how do I remove it?
    Thanks to all.
    OldHog66
    I don't see any reason to remove it. Couple layers of masking tape and cut around with a razor. When its all done cut with the razor again. Bob
    • rousseau
      hillbilly member
      • Jul 2003
      • 261
      You can't use plain masking tape. Your powder coater will/should have tape that takes the heat. I took my frame to a locksmith and got a key made without having to remove it. Tell the locksmith it's a briggs & stratton.
        When you powder coat something how hot does it get? I never relized that there was heat involved. I've never done it. I know first hand it's a bitch to blast it off. Bob L
        • jmanjeff
          • Apr 2008
          • 252
          around 500 i think
          Jeff Bowles
          Arkansas
          Membership # 14023
          1957 Sportster
            Originally posted by OldHog66 View Post
            how do I remove it?
            Thanks to all.
            OldHog66
            Get a strong magnifying glass and a bright light. Look on the frame neck on the lock boss. You will find a small hole with a pin in it. Mark it and take it to a great welder. Have the welder weld a small blob on the end of the pin. Pull the pin upwards with a pair of pliers. Now you can remove the lock mechanism.
            • OldHog66
              • Jan 2009
              • 113
              Thanks everyone!!!!
