There is an old, as yet un-popularized sport, of riding an OHV Big Twin. There are two types of set ups; the jockey lid, and the rachet top. The jockey lid was (basically) a 1936-1952 tank shift lid on the transmission. This lid is used for the suicide clutch (though not exclusively). The suicide clutch pedal is from the early Servi-car and is a reversed duplicate of the right brake pedal. The pedal needs enough slack (adjusted from the clutch lever rod) so that it bounces, or it's hard on the clutch push rod and clutch push rod bearing. The suicide clutch operates like an automobile clutch pedal. You let out the clutch and you're going to move forward real fast. In the words of Bill Kennedy (eldest brother of Pat and Mike)..." You pack an ol' lady on back that has big feet, and she can easily knock the shift lever into gear at a traffic light... and then you'll be moving real quick to correct the problem". If you didn't know, a jockey shift is a lever (there's even a pre-40's Harley part number for one) connected to the "jockey lid" '37-51, (but will fit on a '37-78 transmission) [34804-36; and now replicated by Tedd this year]. In '51, the shifter lever (on the lid) changed to a 5/16"-24 threaded hole (available AM) and allows the lever to be secured with one bolt, and no modifications. The jockey lids and rachet tops used a couple of different drums until '72; but with the same shift pattern (dictated by grooves cut into the drum); until a '73-78 (FX) (cast) shift cam was introduced. I don't know if an FX shift cam will work in a jockey top, if not, then your shift pattern for ALL DRUMS will be: back for first, up for neutral, up for second; third; fourth. (You know which gear it's in by the position of the stick; a neutral can be found between every gear.) I may not have all my dates correct, but the re-popped parts are out there. The Jockey lid is the safest for a suicide setup because a neutral can be found between every gear, albiet, it is merely setting the "selector" steel ball between locator notches, and not a neutral position you want to rely on if you're attempting to start the machine.
The next style of jockey shift is the rachet top. If you use the (34019-73) FX (available AM) CAST SHIFT CAM in the lid, the shift pattern will be: forward for first; back for neutral; back for second; third; fourth. Only one neutral. The '59-'64 rachet top (available AM) has a neutral indicator switch boss, that holds a sending unit to a dash light. The lamp is in the middle of a three-light dash. You can see when you're in neutral. The rachet top is a selector that finds the gear before you do. Two opposing spring loaded prawls become the focal-release-point, that unleash the built up torque, via the foot clutch. The rpm; throttle; spring-prawls and foot clutch operate in harmony; and create a sport completely separate from any other Harley-Davidson "ride". You experience unweighting and torque release through curves at relatively slow speeds (akin to ocean surfing-on asphalt), something that you won't feel with the traditional hand clutch and foot shift. (It's a bolted changeover. No OEM parts are harmed or destroyed in the process.) The shifting mechanism in a rachet top is so fast, that your hand is only on the lever ball for an instant. Most people won't even see you shift. The Saturn-ball [34010-36] is the only way to go (it has a long history). Your fingers catch on the ring. Gas feed on a real Harley, as stock, is through the handlebars to a Linkert. You turn the gas on...it stays on, until you turn it off. Early cruise-control.
Leaving our place is a downhill section. When the transmission is cold, sometimes, I use a slightly more than half-way position on the rocker clutch, along with the motors slow matching rpm, to speed-shift between second and third. The slow-turn of the gears and shafts pull the transmission into third like butter. Just a real nice way to wake up in the morning. There's no other motorcycle experience like it. The machine becomes an extension of your mind. Have you ever seen that poster of a rider standing on his (Corbin Gentry) saddle? You know the one...on his Indian...out in the mesa-desert...arms out ...at about 45 miles an hour? The feeling's not exactly like that, but close.
About the jockey shift, '64 Bob told me,"Aw man.. it doesn't look right on a swing arm..(grumble)... but it'll look OK on a rigid frame..." Then I said, "It wouldn't look as good on a '64 (even though the frames are the same) because your headlight is under a cowling. It "fits" my '59 because the headlight is separate". And he didn't say anything else about it.
