Kicker Pedal ID Help
  • clanky
    • Nov 2018
    • 80
    Hello....I know this isn't an accessory, but wasn't sure where else to put it. I have this kicker pedal that doesn't look like a Harley pedal and was wondering if any of your guys might be able to ID it? Thanks much.
    This gallery has 3 photos.
  • Jerry Wieland
    • Jan 2006
    • 2007
    Not an expert on pedals but that looks as HD as you can get. Missing the outer cover to hide the center stem nut. Jerry
    • 1939wl
      • Oct 2023
      • 160
      Agree with Jerry 100%, definitely H-D, just missing the end cover. (shown in 2nd picture). Correct spring, and bushing etc.
      Member # 8964
      • clanky
        • Nov 2018
        • 80
        I just assumed it wasn't H-D, I guess because of the lack of an end cover, it looks like it never had one. Thanks so much for the help.
        • Tommo
          • Sep 2001
          • 1318
          The end cover didn't appear until 1929
          It looks like a real nice 1916 to 1928 pedal to me
          Peter Thomson, a.k.a. Tommo
          A.M.C.A. # 2777
          • BigLakeBob
            • Jul 2010
            • 2757
            What about the opposite (kick arm) side where the studs don't come through and no nut?
            Bob Rice #6738
            • Tommo
              • Sep 2001
              • 1318
              Thats something I didn't notice Bob so perhaps it's aftermarket.
              I still say the end caps didn't appear until 1929
              A.M.C.A. # 2777
              • Steve Slocombe
                • Jan 2003
                • 2168
                The pedal rubbers had tapered ends until abouit 1934, and a cadmium centre spacer in the 1930s, so that one looks more 1940s onwards to me. Harley used the bicycle pedal style from 1916 until the cheaper lollipop style came out in 1963. If we want to get into the undergrowth, the flat spring washer has a 1930 part number and the pedal pin bushing a 1931 part number. This means the earlier pedal pins have a slightly smaller bolt hole.Part number remained 2091-16 despite several changes, as the lollipop style was intended as a spare part replacement for the bicycle type.
                • FLFD7
                  • Feb 2021
                  • 729
                  Are you sure that’s not an Indian pedal? I had thought that the Indian pedals had the rivets on the crank side and the Harley’s had the nuts on the crank side…
                  Looking at Greers catalog the diagram looks like the rivets (actually look like PEM studs) on an Indian pedal.
                  Credit to Jerry Greer for the diagram
                    • 5952
                    Just for reference; this is a 1916 Harley-Davidson single block step starter pedal. It's not very friendly so I assume it was replaced at some point in 1916 with the bicycle type.
                    • Steve Slocombe
                      • Jan 2003
                      • 2168
                      Thanks Eric, that shows the tapered rubber and the way Harley kept the same part number for later versions of the same part.
