Any info regarding Harley Big Twin enclosed rear chain guard
  • Hack
    Senior Memeber
    • Sep 2010
    • 91
    I just got this and am currently removing layers of petrified protective greasy crud. I believe the outer is Superior but I'm not sure about the inner. They appear to go together and fit up pretty well however I'm not sure how they were attached together. The inner side as can be seen has a lip and fits nicely into the outer, The lip has 6 holes in it and are all tapped 8-32 and do not appear to be home made. There is also no indication that any threaded ears were removed from the back to line up with the screw holes on the outer like on a primary case. Also the master link/lube door on the rear radius has gone missing along with the little bracket on the front that goes to the primary case. I think those can be easily made up. Any pictures or first hand knowledge regarding fitment, etc. would be most appreciated. Thanks, John
    This gallery has 5 photos.
  • Rubone
    • Aug 2004
    • 4762
    They are "interesting " accessories but generally a POS. They don't work well with modern tire profiles or modern chains Not enough room. Earfly ones don't have the access panel. They have several small brackets to hold them in place. If you are planning to ride your bike with any regularity, hang it on the wall...
      Gadfly from the Dumpster
      • 8208
      I don't understand, Robbie!
      Low profile tires would never suit a rigid in the first place, chainguard or not. If a "modern' chain is an O-ring to keep the mess off the tire, then it would be redundant with an enclosed chain anyway.
      You just think they are ugly.
        • 8208
        Yes John,..
        8-32 is what I found, and there is no way the 'inner' and 'outer' were not produced as a mated assembly. They are equally difficult to deal with.
        As my previous pic shows, clamps and attachments were often fudges. I ran it without removing the tab to nowhere, for fear it might really fit something.
        • Hack
          Senior Memeber
          • Sep 2010
          • 91
          Yes John,..
          Ok, so what are they for and how are the two sides of the guard attached to each other? How is the inner held in place? Those little holes line up with nothing.
            • 8208
            On mine, John,..
            The "outer" half is held at the backing plate and oiltank, but the 'inner' slips over the reinforced lip on the outer (as shown in your fourth pic), and is secured with seven or eight screws tapped into it.
            Naturally, the screws cannot be too long, or they will hit the chain.
            • dommi7
              • Jul 2001
              • 109
              I think you have inner and outer from 2 different versions.
              one has ears like the front chain cover where the screws insert from the left side of the bike toward the right and the other version has an overlapping seam with screws that drive in toward the chain. I may have examples of each, if I run across them in my stash I’ll post photos.
              Ralph
              • Hack
                Senior Memeber
                • Sep 2010
                • 91
                I've pretty much come to the same conclusion. I've run across a few left side covers over the years but bought this one because it actually had the elusive back side still with it. I'll keep looking!
                Thanks, dommi7
                  • 8208
                  Mine is obviously different, Hack,..
                  As it doesn't have the inspection door at the rear.
                  I had it packed for D-port last year, so its available!
                  .....Cotten
                  • Sidehacker
                    • Sep 2012
                    • 235
                    Actually the front that you can buy at v twin but the.back is one from the ⁷shorter one which i have but was told it was for first swingarm in 58 although I thought they only worked on rigids. Could be a 45 but I have a complete short one . I need a pattern from the bracket that has two bolts that bolts to front cover
                    This gallery has 1 photos.
                    • Sidehacker
                      • Sep 2012
                      • 235
                      Thats first picture I've ever up loaded. It may be dark but its an accomplishment. Lol
