1939 Big Twin Rear Fork
  • Shane Briggs
    • Nov 2011
    • 76
    Need a 1939 BT rear springer fork. Will purchase outright and/or trade my 1940 fork. Thanks
    • 5995
    '39, and '40 are the same kicked forward rigid fork. The spring fork may have different numbers between 3 and 5, but that can be verified with Palmer's new book. The rockers are all the same and that would be no boss at the zerk fitting.
    • Jerry Wieland
      • Jan 2006
      • 2013
      I believe he is right that 1939 and 1940 BT rigid forks are different. The basic fork is the same but the brake anchor is different. The late 1938 fork might also be the same as 1939.
      Jerry
        • 5995
        I've had a number of early forks and the differences I saw in the brake anchor seemed to show up when electric welding came on line. I'd like to see pictures of the subtle differences, as I have a friend that's building a 1940EL; and I also don't want to mislead Shane.
          • 5995
          I should have dug out Bruce's new book before I spouted off. I see there are significant differences in the brake anchors.
            Gadfly from the Dumpster
            • 8228
            I should have dug out Bruce's new book before I spouted off...
            I'm afraid to get mine dirty.
              • 5995
              That is funny Tom; but Bruce wants people to get them dirty and dog eared so they'll buy another copy.
                • 8228
                Eric!
                I'm glad I kept one copy of the first edition, as it has info missing in the second..
                (And my correction notes are more accurate.)
                If I get laid up, I'll have time to study the second, with clean fingers.
                PS: I already ordered the first three copies of the second.
                • Shane Briggs
                  • Nov 2011
                  • 76
                  Here is the difference in the brake anchors; the blasted fork is the 1940 fork and the painted one is a 1936-7 fork. A 1939 anchor would have been welded and brazed to the fork. 1939 forks would also have the neck slot milled into the side of the stem for the early dampner pin. Thanks
