Harley 1915 Two Pedal Trans. Original Paint
  • Harley 1915 Two Pedal Trans. Original Paint
    https://www.ebay.com/itm/254753799298
    Mark Masa
    www.linkcycles.com
    Harley J JD 1915 ONLY Two Pedal Three Speed Transmission, Original Paint, Patina
    You don't see these for sale anymore, especially with most of the original paint intact. This transmission is complete except for the pedals and pedal crank oil tubes. The pedal crank itself is a fully machined, made in the USA reproduction (Worth over $500 by itself)
    As you can see from the pictures of the internals, it is complete and in VERY good condition. The gears are phenomenal and the pedal crank mechanism works just as it should.
    Mark Masa
    www.linkcycles.com
      that is a VERY nice tranny Mark, should sell fast!
        eBay didn’t like something in the description and pulled the listing. It’s relisted here;
        https://www.ebay.com/itm/254756104002
        Mark Masa
        www.linkcycles.com
          Shamelessly Bumping My Post
          Mark Masa
          www.linkcycles.com
            I was told mine was only worth $1800 and was offered that amount. How could one without the clutch be worth 4 times that?
              was yours a complete original paint 1915 transmission? if not, you are trying to compare apples & oranges.
                Mine is a complete (except pedal crank arms)original paint (what paint is left)1915 transmission with clutch. Mark told me it was only worth $1800.
                  I told you that it was worth $1800 To ME, not having seen the condition of the gears inside and also with the intention of reselling it.
                  Just to clarify, every vendor at swap meets is trying to sell the parts on their table fore MORE than the have into them.
                  BTW: I ended up selling the one I had for under $4k
                  Mark
                  Mark Masa
                  www.linkcycles.com
                    Mark
                    No hard feelings. My original plan was to piece together a 1915 Harley and I will continue on that project.
