Results 1 to 10 of 10
Thread: 1957 big twin frame
    Mar 2017
    518
    Default 1957 big twin frame
    Firstly, I need to get the new Palmer book. With that said, I am not sure how close a 1957 frame is to a straight leg 1954 frame, but I picked up a really nice 1957 frame that still has the sidecar mounts and the neck has not been raked.
    This frame is going to be the new home for my 1954 FLH engine. One of my swap meet special bikes is going to be coming apart and is now going to be a little more refined. Lol
    I am still going to need tanks, rear fender and rear brake assy.
    Who does a good job repairing the cylinder heads, exhaust port etc? I saw Taiwan Ted repairs the heads, but how is their work and their pricing?
    Thanks,
    Ryan
    May 2009
    175
    You're considering sending heads to V-Twin??
    Oct 2016
    165
    Quote Originally Posted by larry View Post
    Sounds like it.
    Menomonie, WI
    1,375
    Well I was hoping someone more knowledgeable than me would chime in but that did not happen so.... The only difference I know of between a late 1954 straight leg frame and a 1957 frame is the neck lock. 1954 and 1955 still use the early uncovered one. Well the date code would be different too.
    I would surely reconsider sending heads to Vtwin although I would think that they are just sending them out somewhere to a contracted repair shop.
    Jerry
    Thanks,
    Ryan
    3,115
    The other difference on early to late straightleg frames are the size of the threads in the coil mounting blocks (5/16 early vs 3/8 late) and the tab for the carb control.
    Mar 2017
    518
    I ran across a few videos of v-twin repairing the heads and just wondered is all. Jim's Harley sends all his aluminum work to them. I saw a set on a bike today that Jim sent out and the fin and exhaust spigots looked pretty good, he also said the cost was 1600 bucks.
    Mar 2017
    518
    I think I can live with that. I am not going to change anything on the frame, but would like to get it checked out to make sure it is straight and true although it looks pretty nice. I need to get a camera!!!
    Thank you!
    Mar 2017
    518
    Quote Originally Posted by badger34 View Post
    A local independent shop sends heads that will require valve seat replacement service to V-Twin, he seems to do so without hesitation so must like the results.
    V-Twin Motor Shop links...
    https://www.youtube.com/playlist?lis...V4FiH7BYx4Qnu3
    I watched these videos and they are why I asked about v-twin.
    Sep 2016
    Oregon
    157
    fyi: the FLH model wasn't introduced until mid production 1955, so if you have a 1954 FLH you have bigger problems...
    Mar 2017
    518
    Quote Originally Posted by knucklehead 61 View Post
    I made a mistake by adding the H. Been working on my 69flh and my finger must have slipped. To be honest, I am not even sure if my motor lived in a straight leg frame.
