Results 1 to 4 of 4
Thread: 6 Volt Batteries - CA95
  1. #1
    Default 6 Volt Batteries - CA95
    Does anyone know a good substitute for the NOS Wet Cell 6 Volt Batteries for a CA95. I have about 1 1/2 Wisco JA-3 batteries, but it would be nice to have something more reliable when not showing the bike. Thanks for any advice.
  2. #2
    Sep 2001
    United States
    484
    Maybe this chart will help you figure out which battery you can use??
    https://www.whitedogbikes.com/shop/c...battery-sizes/
    Jim
    AMCA #6520
  3. #3
    Thanks. I'll check it out.
  4. #4
    Sep 2001
    United States
    484
    That is how I found a battery that "could" work in my Honda CA77 Dream. I just used the 12V/Amps/height/width/length from an actual "Dream" battery and then bought a similar one to "fit" in the spot. I had to modify the terminals with some copper pipe smashed down and that made an extension OUTWARDS from the battery to the cables. It works perfectly too and cheaper than those WISCO JB-2 jobs that are "original" to the Dream.
    Jim
    AMCA #6520
