Results 1 to 9 of 9
Thread: XLCH Stoplight Switch
  1. #1
    Mar 2005
    Huntington, New York - American Zone
    829
    Default XLCH Stoplight Switch
    I purchased a NEW cad-plated brake light switch for my '64. Approximately 20 cycles later, it became a direct short circuit to ground. I disassembled it and found the problem - Chinese 'craftsmanship'. Unfortunately, i can't find a replacement that isn't chrome plated and taking them apart does some unavoidable damage. Besides, I'm concerned about the insulation washer that failed in my current switch failing in the replacement switch as well. Unfortunately, I also can't find a good OEM replacement (my obvious preference). Does anyone have a source for these, OEM or new?
    Thanks...
    Bill Pedalino
    AMCA 6755
  2. #2
    Sep 2016
    Oregon
    138
    i think i have one sportster brake switch left.
    message me your number & i can text pics.
  3. #3
    Mar 2005
    829
    Knuck:
    My cell number (no secret) is (516) 532-6322.
    If you find one, please let me know if its Cadmium, Parkerized, or Black. I believe that they were Cad in 1964. I would choose not to disrupt an original part by taking it apart to just plate it. If that's the case, I'll maul an aftermarket switch, strip it and Cadmium plate it and leave your original for someone that really needs that variety for an original restoration.
    Thank you for looking!
    Bill Pedalino
    AMCA 6755
  4. #4
    Mar 2005
    829
    Well, in absence of an good OEM switch, I figured out the problem with my aftermarket unit. I disassembled it and found that the dished brass contact plate was installed backward which allowed its insulating washer to meander just enough to cause an intermittent direct short. This is a real problem with a magneto Sportster, as the hot side of the brake switch is common and direct to the regulator output terminal.
    I corrected the problem, re-assembled the unit and hid any disassembly damage with Duplicolor 'Bumper Chrome' paint (it looks just like Cad plating) over the holding tabs for the Bakelite terminal plate. It actually looks really good and it appears to work fine. However, I'm still keeping an eye out for an OEM switch!
    Bill Pedalino
    AMCA 6755
  5. #5
    Sep 2010
    193
    Bill
    I looked at the brake light switch on my 64 to check if I had a extra one. I only had the later one. But my 64 switch is painted black.
    Jim D
  6. #6
    Mar 2005
    829
    Thanks Jim,
    It looks like the jury is still out on the finish. I seem to recall that the switch on my original 1964 (when I bought it in 1968) was black, but that's from memory. Since then I've been advised that it was Cad. I have seen them both ways. The Bike will be judged again next year most likely at Oley, so there's time to make the correction before then, if necessary. I do believe that your correct though.
    Bill Pedalino
    AMCA 6755
  7. #7
    Sep 2010
    193
    The other one that I have which was used after this one is also black.
    Jim D
  8. #8
    Quote Originally Posted by Bill Pedalino View Post
    Thanks Jim,
    Bill, I have seen no evidence to believe that any Sportster with the 1957-66 style of brake switch ever left the factory with it painted black.
    I did some searching in my photo library, and most period photos are taken from the exhaust pipe side. However, of the few I found, it looks like a couple are parkerized and others are cad plated. I would say it was a running change during the model year, so both could be correct in my opinion, depending if you have an early or late serial number.
  9. #9
    Dec 2001
    490
    I just found one in my stuff that is cad and not BT because the brkt. is at a 90 degree. Sportster correct?
    DrSprocket
