Results 1 to 10 of 11
Thread: valve cover wrench
    Aug 2007
    Illinois
    289
    Default valve cover wrench
    Early K models used valve covers (18255-52) that required a 1 3/8” wrench. Later models used 18255-52A, which took a 1 ¼” wrench. My question is: Where can I get a 1 ¼” wrench that will fit in my KHK’s tool box?
    I was able to remake a Harley W model valve cover wrench from V Twin (16-0414) to fit the early model (1 3/8”) valve covers that a mechanic removed without my permission and substituted later (1 1/4”) model covers. Now, I am stuck with valve covers that are the wrong size for my wrench. Any suggestions on where I can find the wrench I need?
    George Tinkham
    Springfield, IL
    www.virmc.com
    1941 Indian 841
    1948 Indian Chief
    1956 H-D KHK
    1960 CH
    1964 BMW R69S
    1984 Moto Guzzi V65Sp
    Sep 2010
    194
    I would shop for a 1 1/4 wrench on ebay to modify.Or obtain a piece of aluminum 2024 T3 1/4 thick plate and cut one out on a bandsaw and hand file it to fit the cover. I have made numerous wrenches from aluminum for special applications.
    Jim D
    Jul 2018
    10
    P1010017.jpgThis is a wrench that they make for the fitting on a nitrous bottle. It is 1 1/4 inches and 1/2 inch thick aluminum, it worked perfect on my 1953 K model. They sell them at Jegs and summit or any race shop.
    Jul 2018
    10
    P1010017.jpgThis wrench is for a nitrous bottle fitting it is 1 1/4 inches and 1/2 inch thick and it worked perfect on my 1953 K model they sell them at Jegs and Summit or most race shops
    Aug 2007
    Illinois
    289
    Thanks. It looks like it will fit in my tool box with the other stuff I cram in there.
    George Tinkham
    Springfield, IL
    www.virmc.com
    1941 Indian 841
    1948 Indian Chief
    1956 H-D KHK
    1960 CH
    1964 BMW R69S
    Oct 2016
    3
    Another option (but more expensive) are steel service wrenches from Proto. The image below shows a set I use on K Model intake manifold nuts and large valve cover nuts. If the wrench is too long you can of course reduce the length to whatever you desire.
    https://www.amazon.com/Stanley-Proto.../dp/B0025QHPAU
    Aug 2007
    Illinois
    289
    This looks like the wrench I just ordered yesterday. Thank you for your suggestion.
    George Tinkham
    Springfield, IL
    www.virmc.com
    1941 Indian 841
    1948 Indian Chief
    1956 H-D KHK
    1960 CH
    1964 BMW R69S
    Aug 2007
    Illinois
    289
    The 1 1/4" wrench by Proto suggested by wx507 fits in the tool box nicely and works on the back 3 covers with no problems. It tends to scratch the paint on the generator when used on the front cover. I can slap on a little touch-up paint when this happens or shave some metal off the wrench. It is a nicely made tool, and I am satisfied.
    George Tinkham
    Springfield, IL
    www.virmc.com
    1941 Indian 841
    1948 Indian Chief
    1956 H-D KHK
    1960 CH
    1964 BMW R69S
    Oct 2016
    3
    The 1-3/8” rear EX valve cover is by far the most difficult one to access given its proximity to the oil-return and vent lines. The service wrench needs to be put on a diet to access this area, but with modification it allows access with a bit of room to spare.
    Aug 2007
    Illinois
    289
    Thank you for the suggestion. This is one of the reasons I joined AMCA: to be a better mechanic and caretaker of my machines.
    George Tinkham
    Springfield, IL
    www.virmc.com
    1941 Indian 841
    1948 Indian Chief
    1956 H-D KHK
    1960 CH
    1964 BMW R69S
