1929 402 cam timing data.
  • 1929 402 cam timing data.
    To anyone who has technical info on Early Indian Four motors. Does anyone out there have cam timing in degree of valve opening and closing including piston position measurements BTC, ATC etc?...Also, ignition is timed 5/8 BTC but is that retard position or fully advanced on the mag. Need to check my engine with a degree wheel or piston position measurements......Thanks ...Joe
    Joe AMCA# 3435
