Engine oil
Oil can be a ticky subject. With that being said, I dislike having a different oil for every old machine I own. Ten or fifteen years ago I started using VR-1 20-50 in my 1964 FL with no problems. Then had my 1965 BMW R50/2 rebuilt and thought why not. I had talked to Vech about it and he recomended VR1 10-40 but said since all of my riding was done in summer 20-50 was fine. I run it in my BMW, 64 Pan, 78 Lowrider and my stock 49 Ford flathead with filter, never a problem. The exception being an old brain washed Harley Tech telling me " That's car oil you can't run that in a motorcycle you have to run a special formulated Harley oil in that Pan because it has a special additive package for air cooled engines."
Engine oil
I hate to open this oily can of worms, but I have concluded there may be an underappreciated reason to use high zinc, high viscosity oil. I start the year using 20-50 Valvoline VR1 on my '56 KHK. As it needs more oil and the year gets warmer, I add straight 50 weight VR1. Others have suggested that a lighter weight oil will get to the bearings and wearing surfaces more quickly on startup, but I have elected to use the high grade, thicker oil.
Last weekend, I saw a particular advantage to using the 50 W VR1. I rode to a wedding in a town ~45 miles away at interstate speeds. When I arrived, I discovered the oil tank was empty, the cap was askew, and the right side of the KHK was coated in sticky engine oil! After the ceremony, we filled the tank with 20-50 VR1 (straight 50 weight was not available), and I rode it ~45 miles back home. The engine seemed to run fine with no additional noise.
I have yet to change the oil and to filter the drained oil in search of metal particles, but I may have dodged the bullet on this matter. If the bike survives, it will be in large part because the sticky oil with zinc stayed on the bearings long enough to keep them protected even though oil was no longer being pumped to them. I am tempted to scope the cylinders to see if there is any scuffing.
It may be that this oil saved the bike from ruin. Now, we need to protect the bike from an owner that fails to fasten an oil cap properly! 56 KHK by woods with pump in background.JPGTags: None
