Corbin Speedometer Drive Pinion Gear?
  • Corbin Speedometer Drive Pinion Gear?
    Hello,
    What is the difference between the Corbin speedometer drive 15 tooth pinion, 11181-32 used to drive the 48 tooth ring gear for the 18"x4" wheels and the 15 tooth pinion, 11181-32A used to drive the 50 tooth ring gear for the 19"x4" wheels?
    The pictured pinion I have was out of an Indian drive with the 48 tooth ring gear, but I need one for the 50 tooth ring gear service.
