1912 HD Belt Twin (AKA EVIL TWIN)
Thanks Tom!!Originally posted by T. Cotten View Post"Seasoning", Folks,
Or stress-relief by leaving castings in the weather for extended periods, was a practical process for perhaps a century. Auto motor blocks required it as a matter of course.
Today, cryogenic and other processes are used.
Or should be.
I don't suppose that you'll find "cheap on the seasoning" in the history books, huh?
So if I have another pair of cast-in-india cyls on the shelf, been indoors 5 years, I still might want them outside a few years? .. and then check the decks, the bore, etc?
Steve
The lathe is a 1954 Monarch with a ten inch six jaw Buck chuck.
Heat treat, vibration and cryogenic are common forms of reducing stresses from the manufacturing of the raw material or finished part although, these treatments speed up the process.
I had a computer lock up this morning and lost my update, sorry.
(The dog ate my papers also)
joe
"Seasoning", Folks,
Or should be.
....CottenLast edited by T. Cotten; 09-18-2013, 08:52 AM.
Didn't mean to side-track but: qu "By leaving the cast iron parts in the cold, heat, and rain, over 12 months, or in some cases, longer, the iron becomes very stable and won't change shape after the iron has been machined to shape." end qu
That's very interesting to me, Steve. I am rebuilding a top end for my Chief, and had used cast-in-India cyls. I noticed a very slight leak adjacent to the intake ports on both head gaskets (copper), and presumed that the heads were slightly warped. At the machine shop we gave the heads a brief skimming on the planer (a belt sander used on auto heads), and they showed close to nothing on warpage. The cyls, otoh, DID show about .0015" of a "dip" at the area in question, and I'm assuming that this was what caused the slight leak. So, as to the cast-in-India cyls, I am now curious as to their maturity. And I'm curious to know whether Indian, in the earlier days at Springfield, Mass, were as diligent as your tour guide probably was, about when to use that "old ****"!! I believe that Indian was many times in their history, too cheap for their own good. ........ So thanks for the side-track, Steve!
One of my prof's in college once said that the best cast iron to machine little hobby stuff out of was old window weights, because they've had many years of stress-relief hanging in the jams. I thought, who has time to wait? ..... now I recognize that it's never too late to learn things
I haven't had a lot to do with cast iron.... (well, when I think about it, I have quite a lot of it in my collection)... but I haven't had a lot to do with machining or making parts out of it. *
I do remember my old sheet metal teacher from high school taking us on an excursion, through a foundry that specialized in cast iron.*
The old guy who showed us around the foundry, had worked there for ever and a day and had started when he was 15.
When we where walking from the main foundry to a separate shed, which from memory, was the pattern department, I asked him if the parts that were stacked outside were old sh!t (which promptly got me a cuff in the side of the head from our teacher, who muttered show some respect).*
What I probably should have said was "the old looking rusty stuff", but in the lingo of a 14 year old everything was....well you know!!
Anyway the old guy chuckles, and goes on to explain that storing some cast iron parts out in the elements, is a normalizing *practice for parts that need to be very stable before machining.*
I probably would have forgotten that information, if not for the cuff in the ear.
Anyway, I wonder if Lonnie has been leaving these out in the weather, and that's why they are rusty?
Is that a Colchester lathe?
FillibusterOriginally posted by fillibuster View PostHi Joe!
Where did you get the flywheel castings, and what material are they?
Lonnie at Competition supplied the wheels. I believe they are nodular iron and are good quality wheels proven in my 14 Ghost.
Bob
" I would rather take a beating vs uploading pics...."
Me to .
joeLast edited by Slojo; 09-18-2013, 09:11 AM.
Looking forward to reading this thread on cold winter mornings. Add a cup of coffee and it's a good way to start the morning.
Dick
Hello Joe,
Good seeing you at Davenport. Austin and myself will be keeping up with the build and look forward to your posts. Hope to see you at Barbers.
Cory,
Thanks for accepting the challenge, I would rather take a beating vs uploading pics....Last edited by knuckcrazy; 09-17-2013, 10:03 AM.
Hi Joe!Originally posted by Slojo View PostAn early rise this Sunday morning and ride into Stockbridge with fellow Cannnballer Chris Price for the annual all clubs show. A little rain dampened many riders spirits and limited the turn out . Those who showed were not disappointed,. as usual a good turnout. After the ride back the Ghost was put away wet and run hard, a good cleaning this week will bring it back to its glory.
Tonight's focus was the carburetor on the Barber bike a 1913 Harley twin. This bike had not run for maybe 95 years and require a cautious tear down and reassembly over the summer. The 13 was first run out (opened up) at Wauseon. That ride turned out to be disappointing , only 40 mph with Dale Walksler following closely (eyeing up the 2013 competition) . The needle jet cam was set lean adjusting this rich should produce better performance. A ride is planed for this week.
Once the carburetor was finished priority shifted back to the flywheels, Finishing the outside diameter and holding tolerance is difficult without coolant on an OD grinder. The small grinding wheel is at disadvantage against the large flywheel. Grinding produces heat and heat expands the outside dimension of the flywheel. . This is where experience and mostly patience pays off. The end result, at room temperature for an hour all four wheels measured within .0001"
Steve
Grinding the outside diameter of the flywheel does improve the finish reducing drag. It also aids in crank pin location later on in the process, stay tuned.
joe
Todd, a local welder helped me out of a jam on pedal bottom brackets today. Convenience has its advantage some times. Todd also took a look at a Knuckle transmission case that Razor threw in the towel and said if Razor could not weld it he would not willing attempt welding it. Obviously Todd knows Razor and like everyone else, to know Razor is to respect Razor.
Good news, Mark, for those of you who rode along with the Ghost build may remember him as Spark (grinder hand) has survived a hip replacement and neck surgery and is back on his feet. Spark will be instrumental in grinding parts that I choose not to grind in my shop due to the difference in quality of equipment and experience. Like Razor, Spark is at the top of his trade.
The Barber race bike is weighing heavy on my mind and the thought is to go back to the carb for more tweaking, this will delay progress on the Twin.
joe
"Another case of dyslexia or to many lunch time Lagers? Look at these vin numbers, typical of the 1912 through 1914 years. This 13 will be running Barbers Century laps this October."
"Two sets of flywheels and a weekend worth of work. The outside diameter of all four wheels are O.D. ground within .0001" This will simplify locating the crank pin hole accurately. Next, break the sharp edges, match the casting odd shapes and then machine the finish taper holes."
Awesome stuff, this is as good as our forum get's - thanks Joe and Cory!
Steve
joeLast edited by Slojo; 09-15-2013, 10:48 PM.
