Completely ORIGINAL 69 XLCH
  • Sargehere
    replied
    I have never, ever experienced Judging, despite your preconceived notions, to be driven by your imagined brand prejudices, Tom, in almost forty years. Even my lumping of bad reproduction frames together by calling them "Taiwan Tedd's" doesn't exclude someone starting with one of his generic frames and perhaps making it right, but out-of-the-box, just bolted together, there's way too much wrong with what you buy out of his catalog. That's what makes it interesting.
    I see you looking through the wrong end of the telescope, again. We're not, "dictating whose reproductions are gold, and whose are garbage," at all. We're judging where the restorer ends up, regardless of what he started out with, but talking to you is tiring. You know you're right, and facts will not dissuade you from your imaginary nightmare.
    Yes, a V-Twin generic frame, unmodified, is an "obvious reproduction." Given a lot of work, like filing down electric welds to look like brazing, perhaps,and relocating many of the details, and replacing things like flat-plate rear axle hangers with correct cast ones, and on, and on, you could probably make a silk purse from a sow's ear. But the effort is probably not worth the effort, nor cost-effective, when better starting material is available.
    It's unbelieveable to you, I understand, but the judges don't care what you started out with, only what you end up with and bring to the judging field, AND IS IT FAITHFUL TO THE ORIGINAL YEAR AND MODEL IT PURPORTS TO BE?
    replied
    Originally posted by Sargehere View Post
    A Taiwan Tedd frame with NO hallmarks ain't gonna cut it. A pretty-accurate Race Frame Engineering frame will. That's the the fire we're holding the feet of all the makers of the junque parts to.
    Wow!
    The AMCA is going to start dictating whose reproductions are gold, and whose are garbage!
    Brilliant!
    There can't possibly ever be a conflict of interest, huh.
    Thanks Sarge,
    It's all so clear to me now!
  • DanM
    replied
    Get it judged
    hey Cool AC
    Bring 'er out to a meet and have it judged. If it is all original, then others restoring a similar bike will appreciate being able to take notes from it.
    You might learn about a few things about the bike while at it.
    Basically the judging sheet breaks the bike up into around 20 sections, and each section is judged. you start with 100 points. any deviations have points deductions- 1/4 point, all the way to 6 points. The deductions are totaled, subtracted from the 100, and you have a score.
    There are levels you go through- Junior, Senior, winners Circle. You need to reach minimum points levels in each, to move up. Even if it is 100 points,, you start with a junior ...
    It is an enlightening process, and many enjoy the excitement of the score sheet.
  • moon wolf
    replied
    Well said, Murph and Michael. The original poster had a legitimate question that was mostly ignored while others went off on a tirade. I do appreciate Kevin's remarks, though, and his saying that this was not the place.
    It sounds like a great bike and you certainly don't have to apologize for getting a good deal. I'm on the other side of that debate. I'm glad you rescued the bike and gave it a good home, and if you would have offered the guy a couple hundred less for it and he accepted, more power to you.
    For years I tried to buy a Chrysler Airstream from an old fellow who refused to sell. It was sitting in a shed at the edge of a field on the bank of river. Over the years, trees grew up that would have made it very difficult to remove the car and finally one year the river rose, the bank collapsed, and the car fell into the river, but by then it wasn't worth much anyway.
    Even if the guy had sold it to me for just a hundred bucks, he would be well ahead and a rare automobile would still exist.
  • Paquette
    replied
    MURPH--You SIR have given us one of the most brilliant posts I have read here in a looooooooog time--Thanks--Michael--6671
  • murph
    replied
    I really am sorry about the judging problems. I don't comment because I don't no anything about it, but does every catagory have to turn into the subject of the judging problems?
  • Chris Haynes
    replied
    When you take one model machine and turn it into different model that is not a restoration. That is counterfeiting. A reproduction head on a 1940 UL is still a 1940 UL. A set of 8 valve reproductions road racing heads on a JDH and it is no longer a JDH. It is a counterfiet 8 Valve.
  • Northwoods_Maine
    replied
    Too subjective???
    Sargehere - "A Taiwan Tedd frame with NO hallmarks ain't gonna cut it. A pretty-accurate Race Frame Engineering frame will. That's the the fire we're holding the feet of all the makers of the junque parts to.
    Use common sense. (I know, "what a concept!") We don't judge from ten feet away, we get up close and personal with the bikes. We know there are going to be repro frames, and what to look for. A reasonable repro, like a year-and-model-specific one from Australia, right now, is a far cry from a "Generic Panhead" frame of five years ago. It can be done: erasure of the "obviousness;" not to "fool the judges into thinking it's original," but to become a "Passed" repro frame, not an "obvious," repro, meaning incorrect in easily detectable details. A higher standard, if someone expects their bike to make the Winners' Circle of Excellence.
    The rules adopted don't say ALL repro frames are a six-point deduction. They say "obvious reproductions," meaning generic frames with glaring inaccuracies, like toolbox mounts in the wrong place, or of the wrong type, or any of a hunded other errors. What's there has to be correct for the year and model of the bike."
    Never had a bike judged and may, or may not, ever in the future (nothing to do with the politics and controversy here), just not my 'thing'. But I would make the observation that it would seem from the above that we're opening a whole can of worms with each individual judge having his/her interpretation of what's an "obvious reproduction" from a not-quite-so-obvious reproduction. Food for thought. Seems to me that the judging criteria should be based on a concrete, known set of standards, not one's interpretation of the word "obvious".
    replied
    It's obvious to me that these changes are because of early H-D fakes. Early H-Ds are huge money bikes and good counterfeiting was only a matter of time. Now you have to ask yourself (as a member of the AMCA), should the AMCA have involved itself in recognizing this trend ? If you say YES; then you have to adjust the judging rules. If you say NO, then you condone allowing fakes. Of course there is a lot of variation in the amount and quality of reproduction parts in a restoration, and that is what restoration is all about. That's why the rules have to be carefully scutinized. Steve Dawdy is a great listener and I'm sure he would welcome constructive ideas.
  • Sargehere
    replied
    Originally posted by bmh View Post
    cool AC,
    Maybe once we have a published set of rules and guidelines which are currently in use for judging someone may be able to help you with your questions. Until then you and everyone else are on their own. Who knows what they may be looking for at the next meet, or if it was the same as the last or will be the same at the next.
    Sorry, Brian, that you don't understand that judging changes like were made at Eustis in January are made only at BoD meetings, which are semi-annual, and judging rule changes are rarer than that. The BoD put the rule changes in place at the Eustis meet, trying to run the entire season under the same set of rules. I judged at Eustis. It worked pretty well. Now, it's been done again at Oley, that I didn't get to, and Denton, but there hasn't been any drop off in bikes entered in judging compared to previous years (Oley) or what would be expected, for the size of the well-attended inaugural meet (Denton).
    Some of the members are all worried that Brit or German or Japanese bikes are going to get some kind of "free pass." NO to that, too. I've already heard from at least one Brit and one Canadian offering all the detail our marque judges will need on British VINs and they also have the poop on frame-and-model years. Steve's working on the Japanese info. There are entire clubs devoted to Japanese bikes, and they're on board.
    It didn't happen overnight, but Steve Dawdy is working hard on getting it all put down in writing, and it will happen.
  • bmh
    replied
    cool AC,
  • Sargehere
    replied
    Originally posted by junkyarddog View Post
    I could call you testy, but i won't. I've been around a long time, but don't know what the old boys do. I know you have justified cause to jump at the whiners on here...
    Well, thanks for that, 'Dog. I think that we all could use less whining around here, and I got fed up with it and decided to confront it, is all. As I have already heard from many other members, it's TIRING! No minds will be particularly changed by more whining about the past.
    What's done is done, and there's no going back, despite the deperate hopes for some miracle of the Wayback Machine by the dispossessed. Most knowing members, I think, have decided that fact, and are more eager to get on with the future than continue the debate the coulda, woulda, shouldas of the past. It's over.
    but i wish people would refrain from turning this forum which is a great place for helping fellow members sort out problems and postiing information. I hope people will quit using this site as a spitting contest.
    Jim
    Amen, Jim!
    BTW, the forum that presently helps people by answering motorcycle questions, with a minimum of conflict, is CAIMag dot com/forum. There are some very knowledgeable people over there who even gather 'round and gang up and chime in, to give the consensus of many minds to legitimate Indian and Harley questions, at least.
    The archives ("Search") over there consist of over 40 thousand posts answering questions on about "everything" Harley and Indian related. This forum, OTOH, has devolved pretty much into the AMCA's political shouting match, accomplishing little. Sorry!
  • junkyarddog
    replied
    I could call you testy, but i won't. I've been around a long time, but don't know what the old boys do. I know you have justified cause to jump at the whiners on here, but i wish people would refrain from turning this forum which is a great place for helping fellow members sort out problems and postiing information. I hope people will quit using this site as a spitting contest.
    Jim
  • Sargehere
    replied
    You don't know me, SilentGrey... If you did, you'd know I'm about the farthest thing from a member of the "good ol' boys network" you'll ever find. I've never been a BoD member, though I've known many. I haven't even been an officer of a chapter since Seaboard, in the 1970s. My closest contact with the BoD died with Peter Heintz. The present board members aren't even acquaintances of mine.
    I go back to the days of Doc Patt, Ernie Biddle, Earl Chalfant, Bob McClean and Lou Lichva. Do you even know who they were? (all deceased, now) They were the dedicated heart of the club when I joined, as a kid in my twenties (actually, I joined a couple of years before Bob McClean brought his first motorcycle, the white Schickel, to show at Fort Mott) and the 'swapmeet' parts of National Meets were members opening the trunks of their cars and trading --actually trading parts to one another that they knew the other needed to complete his pride-and-joy. No one got more than $25 for a complete fender, or $5 or $10 for a tailight. That's when antique motorcycling was fun.
    There was no eBay, no internet, and Steve McQueen was still alive. The Las Vegas auction of his vehicles was the seminal event that ruined antique motorcycling as an average Joe's, poor man's, hobby. Big $$$ suddenly discovered antique motorcycles, and prices for everything went through the roof almost overnight!
    I have seen judging and done it, from Doc Patt, through Peter Heintz and Kevin/Robin. "Agendas?" What on earth are you talking about? Both you and Cotten talk about "agendas," but I've yet to encounter one. These latest judging changes are exactly a last-ditch defense by the club to keep counterfeit bikes that never saw the inside of a factory, whether it be in Milwaukee, Springfield, Birmingham or Osaka, from reaching the pinnacle of recognition as examples to be emulated, the best of the breed, "Circle of Excellence," when it comes to antique motorcycling. Newly-minted 8-valve head kits do not make an otherwise common "23JDCA" a "factory racer!"
    Repro parts will keep this hobby alive for coming generations. Most of this stuff isn't being made anymore, in case you haven't noticed. The rules now in place will at least enforce that the repro parts that find acceptance are the best, and most faithful-to-originals that can be made, not chrome plated offshore junk accepted as "good enough." If that's an agenda, I like it!
    And Kevin, I don't know why, nor is it important. I just know that you shouldn't have. You votes wit'cher feet.
  • silentgreyfello
    replied
    Take this from someone who's been around the Antique Motorcycle Club almost 40 years. .
    Yes, take it from another of the "good ol boys network". They will always be truthful. They don't have agenda's. Their meetings are trasparent. They spend our money frugally (museums, foundation). Their leader is very smart, and always treats people with respect. Yes, take some advice from the guy who tells you to take it from him because he's "been aroud the AMC for almost 40 years".
    Back to your original question, the judges are very helpful and will steer you right if you choose to have it judged.
