What grade Walnut shell needed for interior fuel tank cleaning.
I want to Thank everyone who recommended the Evapo Rust for inside fuel tanks. I completed my 2 tank project cleaning up the inside of the lightly coated rust from sitting many years without fuel in them. It seemed to work great and I did add Marvel Mystery Oil to the tanks for a few days rolling them around to coat the insides before mounting and adding fuel hopefully very soon. My question on the reusing the Evapo Rust, I had used 3 Gallons to fill the tanks one and a time and after doing both tanks the color of the liquid turned black and I wasn’t able to see to the bottom of the bucket I poured it all into. I would normally discard it all and wondered how much strength could possibly be left in the liquid to possibly use again on something else? It’s all back in the original 3 gallon containers but Unsure if it’s worth keeping. It only cost me around $90.00 for the 3 gallons anyway. Thank you all again. Good Stuff!
The label is correct. Don’t worry if it gets on the paint. It’s also biodegradable and can be poured down the drain.
I’m going to use the Evapo Rust as I got 2 gallons at Harbor Freight for under $60.00. I was going to go with just one gallon however 2 will almost fill one of the 2 1/2 gallon tanks and I won’t have to turn them as often. It says on the label doesn’t harm good paint which I’m going to do my best not to let it get on the exterior if possible. Thank you everyone for setting me straight with the walnut shell packed tightly in the dryer scenario. Ride on.
Folks, I got it. Gadfly, Thanks but since I didn't meet the criteria for this award I guess you are stuck with it.
Originally posted by KNUCK View PostI actually put a large hand full of screws, nuts and bolts in the tank with a little gas....Originally posted by T. Cotten View PostI bet it took out dents, too.Knuck didn't get it, Folks.Originally posted by KNUCK View PostGood old American steel is too tough for that to happen!
He's lucky he didn't get the Darwin award using gas.
Darwin-Award-I-warned-you.jpgLast edited by T. Cotten; 06-03-2026, 11:04 AM.
I actually put a large hand full of screws, nuts and bolts in the tank with a little gas or WD 40 and start shaking by hand. I do it off and on for a few days and things really clean up nice. Flush out with gas thoroughly and ready to go. As yours is not really that bad so should be an easy clean up.
Agree on Evaporust. II use it a lot on many different parts to remove rust. Also available @ Harbor Freight.
I've had good results with Evaporust, it works better than vinegar.
vph-d
Evaporust available at Home Depot (Lowe’s has an equivalent by another name) works very well and is non corrosive. Vinegar works too but should be neutralized afterwards and leaves flash rust issues. Evaporust works best at warmer temperatures so leaving in the sun speeds things up. Another benefit is it can be used over and over but eventually loses potency. Not terribly expensive either.
I appreciate the replies so far and am in no rush at all since protecting the exterior paint is foremost. I’ll highly consider the acidic vinegar or citric acid as I use vinegar to clean other metal surfaces at times. Certainly test on the backside underside of tanks first to assure myself. The spinning dryer scenario would have been a tightly package tank not able to move at all, bubble wrapped and taped packed inside blankets. Any further suggestions and advice is appreciated. It’s not really bad inside at all as it’s surface dust rust I don’t want diluted in fuel even with a filter inline.
I would not put a tank with good paint in a clothes dryer and let it spin. No matter how well you have it wrapped in blankets. Something unexpected could happen and cause something to rub through the paint or cause a small ding. The most unexpected things happen when you least expect them. Lots of other products to put in the tank to remove light rust that won’t damage your paint. Sounds like vinegar would work fine for your rust issue, Why take the risk of having it spinning in a dryer.
Go to the store and buy some citric acid used for canning. Mix 3-4 oz with 1 gallon of warm water. Pour in the tank and let it sit for a day. Rotate the tank on each side . Continue doing this until all of the rust is gone. Flush out the tank with baking soda and water. Let it dry. Will not harm the paint .
Walnut shells won't work for what you want to do. They need to either be driven (air blasting) or in a vibratory tumbler. Simply spinning them over in tank won't do much. I've done thanks for HOURS in the dryer with actual tumbling media and barely hit the rust -- walnut shells won't do anything and will leave a mess of dust and crap to clean out. They really are a very poor choice for this application.
Also, I would personally never, ever, ever put walnut shells in any fuel or oil tank. It can be nearly impossible to get all bits of shell out. They will swell, they will get stuck somewhere and they will be a PITA.
I haven't read about this blanket and dryer thing . . .I've done it more than once:
A while ago, Mrs. Chuck started hinting she wanted her own motorbike. At roughly the same time a '67 XLH appeared on fleabay. I lost the auction; but the original "winner" didn't pay up. I wound up with rolling pile of parts with a clean '67 title and parts spanning 1967-1976. So, let's build a girls bike. First
If you have perfect paint; consider vinegar. Cheap, very effective, won't damage paint.
Simply fill the tank to the brim with vinegar. Leave for a few days, rinse with VERY hot water and immediately slosh WD40 around to stop flash rust. You'll have a completely clean tank and no paint damage at all.
