Results 1 to 10 of 20
Thread: Gas tank cleaning with acetone
    Aug 2010
    San Diego, CA
    123
    Default Gas tank cleaning with acetone
    I'm getting ready to remove the kreem coating inside my gas tanks (paint not an issue) but can't find anything that is acetone resistant in order to seal the various openings. What are folks using and where can I find it?
    Louis
    Jul 2017
    NW Ct.
    111
    I don't know if they're acetone resistant or not, but how about rubber stoppers from the hardware store? Hope this helps.....Smitty
    Mar 2010
    192
    I use an old gas cap with a cork or old rubber gasket for the gas fill area. For the other openings I use rubber stoppers or plastic cap plugs. None of these materials is acetone resistant for long term exposure but will work OK for the short time it will take to dissolve the creme. You will likely get some pressure build up during the process so open the gas cap slowly when you check the progress. Unless you're very careful, you'll also get some of the solution on the outside surfaces of the tank when you remove the gas cap but since you don't care about the paint that's OK. Just a bit messy and stinky.
    Aug 2010
    San Diego, CA
    123
    Thanks for the inputs. It turns out I have really been over thinking this. I read someplace that acetone does not effect cork, I had a large chunk of cork in my garage so roughly cut the size I would need to plug the gas line connection holes and filled one of the sides to the brim and put a gas cap on with rubber gasket. The rubber gasket will be trash but those are cheap enough. I'll give the acetone a day or two and see how it turns out. It's a good thing the paint is no concern because those cans the acetone comes in do not pour very well.
    1,428
    The expensive tank sealant remover I bought turned out to be carbon tetrachloride rather than acetone. Having an economical streak, I later used the contents of old Pyrene fire extinguishers, which is the same stuff. It took more than a day or two per tank, and you may need help such as shaking the tank with a handful of nuts and bolts inside. The modern gas is very aggressive, so you need really clean tanks to get a good bond for the new sealer.
    Aug 2010
    San Diego, CA
    123
    So, after I've removed the old kreem liner I'm undecided on what product to use as a new coating. I've looked at red kote and por-15 and both seem like good products, but. There are some folks who don't recommend using any type of liner and I know Cotten mentioned using a phosphate coating on another thread. I've searched the internet and can't find what or how to do this. So Cotten, what product would I use to phosphate coat my tanks and how to you apply it?
    Oct 2016
    164
    Why coat them again?
    Mar 2008
    New Jersey
    100
    I have been using Red Kote for quite a while with great results. Be careful when you use it as it will build up pressure in the tank while you are rotating the tank around with it fully sealed. Due to ethanol in modern fuels, the fuel tends to attract moisture and causes rust in the tank. I am lazy and do not feel like running to the airport for ethanol free fuel every time I ride an old machine.
    1,428
    I've used a two component tank sealer here in the UK on maybe four sets of tanks, but one of them was lifting a year later. The tanks have to be completely clean and dry, you need to warm the tanks as you slosh round the sealer, then it needs to cure for a week at a warm room temperature. The modern wet gas also rusts the steel plugs in brass Harley gas taps, so after a long period standing you cut rust into the valve body the first time you turn it on.
    Menomonie, WI
    1,372
    I would never just coat them because it is 'a good idea'. If they don't need it - don't coat them in fact I go to the ends of the earth not to coat them.
    Jerry
