WLA WL Rear Cain Oiler Pipe off the oil pump Question
  • WLA WL Rear Cain Oiler Pipe off the oil pump Question
    Attached should be a picture of 3575-41A oil pipe for oiling the rear chain. To me it looks like the clip is in the wrong place. I can't find any information on the installation. Would someone have a picture of how the pipe is run? Thanks
    The clip should be loose on the pipe, if not someone may have crimped it on. Once the oiler pipe is connected to the oil pump, the clip is mounted behind the starter spring stud on the side cover of the transmission and the other end is directed to let the oil drip on the chain.
      OK, Now does the tube run behind the clutch actuating lever and kicker pedal?
        John, two clips are required. One is permanently attached to the pipe while the other one isn’t. I sent you a PM with more info.
        Eric
          Eric
          Sorry, Where do I find the PM?
            In your ‘Profile’ see ‘Private Messages’ and ‘Inbox’.
            Eric
              I just tried to reply but it didn't send so I'm trying again. In your 'Profile' see 'Private Messages' and 'Inbox'.
              Eric
                It is shown clearly on page 157 of Palmer's 2nd Edition military book. You do have one right?
                  Thank you Eric, Robbie and Rcamp. I'm learning more about our web page idiosyncrasies. Your information helps me out immensely as I don't have Palmers Military Book. I'll have to get on board with that. What a great resource we have. Thanks again....John G.
