Linkert M741-1 rebuild
  • #16
    As I posted, Harry!
    Greer's lists the 100257, which is "equivalent".
    I hope they both are Greer's own productions, as that's usually decent.
    (Some Greer's offerings are from subcontractors; Trust me, I'm certain.)
    PS: The 841L&R should be the same as the M17L&R venturies, depending entirely upon the quality of manufacturer, of course.
    (On the whole, what crossed my benches from the predominant ebay hero sucked, in one way or another.)
    • #17
      ...whoops, I forgot to mention it's listed as out of stock. I'll see what Todd has to say.
      • #18
        Got a lathe, Harry?
        • #19
          ...Greer's will send me a venturi for an M441 ('41-'42 Indian Four), it's .816 i.d. and Todd says it will fit... so that's good, thanks again!
          • #20
            I'd be really curious, Harry,...
            If the M441 #102457 nozzle might have an advantage as well.
            The Scheb nozzle just had #57 holes, but it would be fun to try them both!
            • #21
              I've changed my mind, Harry!
              The M441 had a 'Bonne' nozzle, like on the right in the attachment;
              M741(-1) shown in the middle, and a DLX63 on the left.
              Note not also the difference in holes, but how high the top holes are.
              Although anything might "run", only trial and error can tell us what is best.
              (It would be easy to put another #57 hole in the 741.)
              PS: The DLX and 741 have a #28 bore; The Bonne has a #28 spigot, but the body bore is a tight #33,
              So who knows how it would run!
              • #22
                The one that was in there:
                It has a fifth hole in the stem, but that hole is not round and I don't think it's meant to be there!
                • #23
                  Replacing a spigot is routine, Harry!
                  PS: What have you got to lose?
                  • #24
                    Uh oh..., Correction time, Folks!
                    The Greer Bonne shown is indeed a #33 bottom bore, but real ones are #28 all the way through.
                    Doh!
                    • #25
                      Parts showed up yesterday, yes they were expensive:
                      First thing I did was to remove the old throttle shaft bushings, there was actually little play in the throttle shaft but all the literature informs you that worn throttle shaft bushings are to be expected, so why go through a rebuild and NOT replace the bushings? I used a 7mm tap, mostly because I've never used it before and it threaded into the bushings without going too far:
                      I tapped the bushing with the 7mm threading tap, and then from the other side I used a thin threaded rod to tap on the threaded tap with a light hammer to to push out the bushing, worked like a charm:
                      • #26
                        So now onto the new bushings. I put them in the freezer yesterday, though I'm not certain it made any difference? I took a wooden dowel and turned down the end of it to fit inside the bushing, then with the bushing on the dowel I inserted it into the casting and tapped it in place:
                        They both went in flush without too much effort, half a dozen light taps with a small 8oz hammer:
                        So now I have to figure out how to ream these bushings so that the throttle shaft is tight, but not too tight! I have a few hand reamers, but not one that small, I was thinking of using another dowel wrapped in 400 grit sandpaper to see if that does it. Ideas welcome!
                        • #27
                          Harry,
                          I have used the sandpaper on a stick often for various situations, including carby bushes.
                          You need to use a full width "stick and paper" to ensure the top and bottom bushes are lined up. The nature of the sandpaper means the backing material is flexible. This will "Bell" the entrance and exit of any bushes you ream with this setup.
                          I find a full width hand reamer is the best tool for this job. I prefer an adjustable hand reamer that is wide enough to ream the top and bottom bushes at the same time. The clearance of these bushes can have an influence on how well an expensive motor runs, so i consider them a cheap tool to have.
                          • #28
                            i would second what Mick says. if the circumference is irregular top to bottom its an air leak. i also note a number of these carb parts sellers make the bushes out of steel, one of the highly respected old timers i mentored under told me they were made of Monel metal and i believe there is documentation to back that up. monel metal, as i understood it, wore better in the application of the rotating shaft. Waiting for Tom Cotten to jump on board.
                            Steve Swan
                            27JD 11090 Restored
                            27JD 13514 aka "Frank"
                            • #29
                              Thanks Mick and Steve, I’m sure that’s the right call! ...ironically I will probably have the correct reamer come in the mail at about the same time I would have finished up with the sandpaper :-)
                              • #30
                                Everybody does it different, Harry!
                                I use a ground quarter-inch rod to align both bushings, and have pucks to press them in gently. The pucks are also counter-bored to leave ~.015" or so exposed. Pressing in too far often puckers the end of the bushing at the bottom of its bore, and Monel is not really friendly to reamers. Sometimes I must line-hone them.
                                This pucker often gives a false fit, scarring the shaft.
                                PS: The only literature mentioning Monel that I can find quickly is the 1930 Indian catalog for Scheblers.
