Sidecar Fender
  • Sidecar Fender
    Over the weekend I was taking apart the sidecar fender in order to have some work done on it. When I disassembled the brace from the fender, these peices came out. There were two each for the front and back. Theye were between the brace and the inside of the fender. There was nothing on the top. There was one piece between the fender bracket to step bolt. Honestly it looks like pipe hanger material and is about 16 ga metal. Rivets went through fender, through the pieces, through the braces and peened into place.
    Are they just used as a spacer? Have them soaking right now to remove the rust.
    They were located here
    and here
