'60 and later handlebars
  • '60 and later handlebars
    Was wondering if anybody knew if the 2-piece bars used on '60 and later models shared the same grip diameter and end thread. I know you can find different bend options for big twin and sportster/servicar, but do they all use the same action sleeve? Are the threads that hold the sleeve on all the same diameter? Any info appreciated
    All the control parts interchange between models and also between one piece '54 up bars and two piece bars. All the components are shared. There are control spirals for both push and pull as well, used for various applications such as lightweight models, right hand shift Srvi-Cars, and Bendix carbs.
      Thanks for the info Robbie!
