Dc 7 throttle cable clamp
  • Dc 7 throttle cable clamp
    Does anyone have a part number/discription/picture of the throttle cable clamp for a 1966 FLH. I recently acquired a DC 7 carb from a fellow AMCA member for my 66 flh. I’m was told that V twin had repop throttle cable clamps. I looked there and they were for 70-72 xlch. Colony has two versions one the same as the v twin and another for earlier sportster/k models has a 90 degree bend in it. These may be correct seeing that the dc carbs were used on sportys for a few years and the one year only FLH was overlooked. With my very limited knowledge of sportys, I seem to remember that sporty dc carbs mounted on the left side had the float bowl reversed from what my dc 7 is. Not sure if that has any bearing on the cable clamp. Clarification would be appreciated. Thank Doniii
    Sporty carbs mount same as Big Twin, the left side one was Servi-Car.
      Not sure what’s worse... my knowledge on sportys or my memory.
          Thanks for the info gentlemen. Speeding Big Twin , for some reason the exploded view I have does not include the clamp.
          Looks like I’m going to have a hard time finding that part. But at least I know what I’m looking for come swap meet season.
          I’m probably going to make do with a similar colony part for now.
          Thank Doniii
            Same part for Sportsters so shouldn't be too hard to find.
              Thank Doniii
              You're welcome. Not all exploded views show the bracket. Even my 58–68 H-D Big Twin catalog doesn’t include it. The two pages I posted above are from my 61–71 H-D Big Twin catalog.
              As Robbie mentioned, the same bracket was used for Sportsters. Two pages below are from my H-D catalog for K-series and 57 Sportster.
              Eric
