Indian four oil pump gear alignment
  • Indian four oil pump gear alignment
    Hi Folks, I tacked this question onto another post but I thought it would be better to start afresh,,, My 1940 oil pump drive gear sits about 3/16" in front of the other gears, but it's almost in line when I turn it around so the flat side faces out. The pump simply bolts to the lower case with no adjustment. All the photos I've seen show the dished side of the gear facing out.
