OEM Indian Chief Magneto kicker arm and pinion
  • OEM Indian Chief Magneto kicker arm and pinion
    I have for sale here an original Indian part #75544, 11 tooth "magneto ignition ratio" kicker arm that has been chrome plated. I have the matching pinion gear (black finish) which I bought as N.O.S. several years ago. I have since located and installed the "batttery ignition ratio" kicker arm and pinion, hence the sale of these parts. The overall condition of the arm is very good, no cracks or stripped threads. There is a place on the back side of the arm where the plating was rubbed off by the exhaust pipe. There are some chips in the plating on the teeth which don't seem to affect the usability. The pinion gear has 28 teeth. The pinion is in a black finish, looks parkerized. The gear teeth are nearly perfect. The pinion has the 10 tooth ratchet on the face. The pinion gear is part #41827. I got these part numbers from a 1948 Indian parts book. This setup was on my 47 Chief. I think the two pieces are worth $240 together. Thanks, Victor AMCA #216
