Where Does 1942 WLC Voltage Regulator Mount???
  • Where Does 1942 WLC Voltage Regulator Mount???
    Hey Guys
    I just got a 1942 WLC and the previous owner had bolted the Voltage Regulator to the battery box.
    I'm trying to re-wire the bike and I want to locate the Voltage regulator in the correct place.
    Can anyone shed some light on this???
    I purchased a mount from 45 Restoration (see photo attachmnt) but I can't figure out if it will work, and if
    so where it would mount???
    Don
    It looks like you have a 12 volt system judging by the -65 Bosch style regulator. That mount hangs off the end of the generator, at any rate.
      The WLA didn't use a regulator. They had a cutout relay that was mounted on the engine.
        The style you have mounts like this
        1959 XLCH
          The original cut out relay mounts on the front of your engine cases inside of the front exhaust pipe.
