Hardware
  • Hardware
    I am working on a 62xlh and want to use the correct nuts and bolts.The parts book is calling nut 7993 a flexloc but it is a nylock.On the brake drum to wheel nuts 7725 are flexloc Now I would like to know about the nuts for the gas tank,front motor mount and shocks they all use nut 7775 the book said flexloc but should they be nylock . Thanks. Mark
    If the book says flexloc then it should be a flexloc. Gas tank, front motor mounts and shocks are all flexloc. Cad plated as well
    1959 XLCH
      Hardware
      Hey Murph thanks for the input .I have seen your work over at caimag. That's what I am going for but you set the bar pretty high.Well I guess I have two order up some cad flexloc nuts thanks again.
