Sportster aluminum rim
  • #16
    Bill, Found the wheel, sent PM.
    Kyle Oanes AMCA # 3046
    • #17
      Robbie, What is the part number on your rims? I'm not sure when the number changed on the rim. Factory parts manuals for Sportsters have always been difficult.
      • #18
        Kyle, The part numbers on the rims are as follows. They are not necessarily the numbers in the parts books, sort of like casting numbers versurs part numbers:
        43008-60 18" rear '60-'69 Some of these are factory drilled for bead lock screws
        43009-60 18" front '60-'63
        43010-60 19" front '60-'63
        43009-64 18" front '64-'69
        43010-64 19" front '63-'69
        43010-61R 19" F&R Racing models with spool hub
        43000-64 18" F&R Trail kit for Scat. This one is 36 hole
        I can photograph any of them if you like except the Trail Kit one.
        Robbie
        • #19
          Kyle,
          I did not receive your PM - please re-send...
          Bill
          Bill Pedalino
          Huntington, New York
          AMCA 6755
          • #20
            This is what I got from a quick search through my factory parts manuals. The 57-67 manual shows 43009-60 front wheel fit 60-63, and 43009-64 for 64-67 fit. The wheel I have, factory drilled and countersunk has the 43009-60 part number. The 59-69 supplement catalog shows part number 42999-60 fits to the rear 60-65. The 57-67 catalog shows 43008-60 to fit 60-65 rear.
            Bill, as I gather from the catalogs the wheel I have is not correct for you. I have some other 18 and 19" aluminum rims, but none are drilled.
            • #21
              My -63 parts book shows 43008-60 for 60-* H & CH.
              MY -71 parts book shows 42999-60 for 60-* H & CH.
              The -71 book shows the screws are for 67-69 H & CH.
              This indicates some kind of change in rear rims after 1964.
              I have an 18" rim marked WM X 18" 43008-60. It has 4 screw holes, which have a small semi-circular relief for the screw head on the rim's outer edge. This rim is approx. 2 7/8" wide, and the stem hole is slightly oval.
              I also have an 18" rim marked 250 C 18" 43008/70 above the round stem hole, and MADE IN ITALY below the hole. The puntuation marks for the inch indicator are backwards, and it uses a slash instead of a hyphen for the year marking. This rim is noticably heavier and more deep than the first rim. This rim measures 3 7/16 wide.
              • #22
                From what I'm seeing in my parts books and in the field is that I need Rim No. 43008-60 for my '64 CH. As my '64 originally came with the bead-lock screws, I would use either rim - with or without the screws. I Looked all over Rhinebeck yesterday and did not find one. Anybody have one for sale, or possibly know somebody that may have one?
                Bill Pedalino
                AMCA 6755
                • #23
                  Rim Screws
                  The screws were used from 67 to 69 with the Goodyear All Traction tire. The alloy rims from 60 to 66 with the Grasshopper did not have screws.
